Hi all-I started this on a different thread on Schematic Requests and moved it here-hope that's OK. I did get the schematic from Crate. I started out with no volume at all and found an open switching jack at FX In (thanks to the forum sticky). I fixed that and now the amp plays fine for about 10 seconds then goes to no volume unless I turn the gain and vol all the way up. Then the note will sound with a hard pick attack then dies out immediately (and sounds bad like it's clipping). Plug the guitar into the Line In and it works fine. So I assume the problem is in the preamp. (The power supply is OK as the filter capacitors after the rectifier diodes measure +/- 29.4 vdc and the spec is 29.5.)
I read some of the archives and thought I'd try to inject a signal to follow. Haven't been able to do it yet. I get 0 ac volts across the speaker leads as well as the input jack with the DMM while strumming the guitar even during the 10 seconds or so when the amp is working. The schematic says it should be 25v p-p @4 ohmns load at the speaker. I hooked the output of an ipod to the input of the amp and also got 0 volts at the jack while the music was playing through the speakers for the 10 seconds. ??? Help. I'm sure you guys could fix this in 10 minutes but hey at least I'm learning. Thanks
