This amp came in with complaints of lower headroom. It's an AB763. I found some incorrect resistors in the PI, and a couple Rk were wrong in the preamp. Aside from that, there is a bit more B+ voltage but I think that's normal for the increase in mains voltage over the years. ?? Anywho I've biased the power tubes, checked every voltage on all tubes' pins, even measured dropping resistors, Ra, Rk, grid voltages etc... All checks out good. However, the PI cathode voltage is at 85v, NOT the specified 110v. All components are correct and connections good. Don't think that would cause such a noticeable problem though. The Vg/k on the PI is ~-2v. I put a 1k test signal in at 200mv and connected the speaker out to a 4ohm dummy load. The distortion on my scope is visible at 23watts RMS of output... or ~13.5ACV. Is this normal? Not familiar with headroom in this amp.
Bandmaster - 23 watts clean?
Is this normal?
Hope this helps.
Originally posted by lowell View PostHa haaaa! Thanks Bruce. Brain fart, don't know WHAT I put into my TI82.I just tuned one up last week and was getting about 12.7 vac across a 100 watt 4 ohm dummy load! ha ha ...
