I'm trying to help a friend fix his Champ 600 RI that went up in a puff of smoke. It was obvious from it's charred appearance that R11 was burnt and it measures 4M instead of 1K now, so I put a new 1K 3W in it and it started to smoke as well. I pulled the tubes and measured test points TP12, 14 & 16 (see attached schematic) and got:
TP16 should be 120Vac, measured 122 Vac (just checking the power coming in)
TP14 should be 280Vdc, measured 299Vdc (seems higher than it should be just because of the slightly high AC)
TP12 should be 366Vdc, measured 422 (seems way high)
My thoughts are that the 6V6 went and took out R11. Unfortunately we have to order one just to check since we don't have one laying around to try.
My questions are:
This may be dumb, but is there a way to test any aspect of the 6V6 with a DMM to see if it is shorted, etc?
Are the high voltages overly high and a concern? If so, there's not much between the wall AC at TP12 and R11 besides the transformer to TP14 and rectifier diodes and filter caps to TP16. Any idea what could be causing the high voltage? I'm used to resistors drifting causing higher voltages, not caps or diode, but I'm still a relative beginner.
TIA!
champion600_reissue_fullmanual.pdf
My questions are:
TIA!
