Quite a while ago you helped me get this thing fixed by suggesting that I change out the 100 ohm resistors to the voltage rails. (the amp kept trying to channel switch when you strummed the instrument) It worked great after that. This last saturday night I had about a half hour to go when I lost sound. The amp shows the dirty drive lit (yellow led) the peddal shows the clean drive lit (red led). The pop I get when I fire off the amp tells me my outputs are still with me (thank goodness). I pulled the chassis out and tested the power transformer and it is fine. I have 30 volts AC at TP 22 and 25 which is good. I have -38.5 VDC at TP26 which is good. I have 0.73 VDC at TP23 which sucks. I checked the resistors R172 and 173. They measure 98 and 98.5 ohms respectively. The + rail at TP 24 is 0 VDC as well. I am useing service diagram ROC PRO 1000.
Can you help me out here? I can only guess it to be CR55 or maybe the sand resistor again. No where near as easy to figure out as a tube amp would be. For me that is. Thanks for your time. DB
