polytone mini brute 378A no sound
    I used the ones the schematic called for because I have several left over from a previous polytone repair.
    So with the metal side down I guess that agrees. Using that sheet I attached the metal side is up your book is agreeing with "style 3", so that would they are in there correct now. I fires up. I have a signal on pin 1 but it's not a good signal. Looks more like a slightly rounded square wave. Nothing on pin 9
      The MJ802/4502 have remarkably high beta and current rating. More so than the MJ15003/4.
      If you mixed up the pinout on your driver transistors, they could have got damaged, maybe even taken the LM391 with them.
        Q1/2 are the NSDU07/57 - originally from National Semi. - their pin out (per the NSC data book 1982) is for a TO-202 package 55 which has 1= emitter 2 base 3=collector left to right with package oriented with bevel "up" - front view.
        This doesn't match the MJE pin out.
          The MJE legs have to be bent to fit in the proper hole, that's where the confusion starts.
          When I get back to it, I will try a new LM391
            Is it possible that the output transistors could have been damaged when using light bulb limiter?
            Hate to have to put all 4 transistors when they are probably good still. THe traces at Q1 and 2 are not that rugged.
              MiniBrute 378 with schottky diode and biasadjustment
              Originally posted by 52 Bill View Post
              Q4 numbers look wrong, Collector and Emitter mixed up?
              Hi. I know this is an old thread, but I have had this amp for repair. Replaced output- and drivertransistors, LM391, and a couple of resistors, and everything worked OK, at least for 1 hour. So now I have to start over again. Any good ideas? How do I adjust the bias?? Regards Torben
                Hi Torben, welcome
                You should start all over, as in you really should start a new thread for your amp instead of adding to the end of a dead thread from 6 years ago.
