This amp (homebrew, similar to 2204) has had buzzing a few times in the past which i've found and fixed. Once a bad mid pot ground. But this time i cannot find it for the life of me. It is NOT a hum, but a buzz very much like single coil pickup noise. Happens with any guitar, (have 3) humbuckers or SC. And if i take my hands off the strings or any grounded part of the guitar it's at it's worse and touching a grounded part lessens the noise more and more the harder i touch it.
I came to believe it is in the first stage because if i inject the guitar signal anywhere after the gain pot theres no buzz at all. If i pull any tube, no buzz. i have literally swapped out everything from the input jack to the gain pot INCLUDING the gain pot and even the belton socket for V1. I then started wondering about filter caps and replaced the JJ 20/20/20/40 multicap with no relief. It then it hit me i never replaced the main 100/100 filter, but wouldn't that cause noise in all stage if it has issues? So at this point i am so lost i don't know what else to do. Every solder joint and past in the first stage was replaced up to the V1B grid. All grounds checked and in the 1st stage i hit them all with an iron or sucked up the solder and reflowed them. Tried different cables too. Tried different rooms to try different A/C outlets.
I don't think theres anything left for you to advise me on, but i have no other resources so i figured i'd at least ask rather than just give up and live with it. Thanks.
