I've been working on this amp and getting nowhere. It powers up but the volume is covered with large popping static sound. My light limiter lights up bright when the static starts.
When turning the master volume the light limiter comes up bright and goes down.
I first thought that the master vol pot was the problem, so I changed it and nothing, the same problem.
Then monitoring the voltages on the regulators, when the popping static started the voltages dropped off. I changed out the LM3886 and the regulators and the filter caps 3300ufs and no positive results.
Not really sure which way to go.
Does anyone have any suggestions.??
also I'm not using the speaker in the cabinet to test this amp. I'm using a direct connection to the amp with a test speaker I have for my bench. There seems to be about 2vdc on the output which goes up and down .
