Hi guys
I'm having a bit of trouble repairing a Vox Ac30 amp. The initial problem was bad sound from the amp.
I had a check inside and found some bulged power supply capacitors. So I replaced them.
I made some notes on the orientation of the caps I replaced, some were the 3 pin ones but subsequently lost the notes.
I have some schematics so think I have it wired up ok but not 100% on it.
Another thing I found was a badly burnt 10 watt resistor located beside the bridge rectifier circuit consisting of 4 x 1N4007 diodes.
Looking at a schematic I believe the value of this is 22 ohms.
I've replaced the resistor and the diodes just in case!
Testing the amp again slowing bringing up the voltage with a variac and the 22 ohm resistor heats up real hot.
So don't want to leave the amp on too long.
So the questions I have are
Why is this resistor heating up so much?
Is my wiring correct?
Also when connecting the load there are 3 connections, green 15 ohms, blue 4 ohms and black common.
What way do I connect up a speaker to this? Don't have the cab at the moment.
Can I just connect blue or green with the black as common?
If anyone is familiar with the insides of this amp and cold have a quick look over the photos to see if the wiring is ok
I would be much obliged.
Thanks for reading!
I'll post some photos in a bit.
Joe
Thanks for reading!
Joe
