I am looking over a Fender Blues Deluxe from the mid 1990s.
It had some problems on the low voltage dropper resistors (R85,86) were 330R and operating at temperature of just under 100 deg c. The 16V zener diodes (CR22,23) in that area had dry joints after coming unsoldered. I repaired and replaced the resistors with 470R as mentioned in many other threads. That supply seems fine now; the temperature is down to 60 deg c and the supply looks good.
It's sort of working fine but there is a low level hum that I am not sure if this is characteristic or a fault. I would love to hear some comments/suggestions of other things to check out from others with experience of these amps.
Some observations/measurements
Switching round the pre-amp valves doesn't seem to alter the noise levels.
With V1 removed the amp is pretty silent.
Transformer leads are in a big not and the heater supplies are not twisted together - I wondered if there are any suggestions on improving this?
B+ is slightly high compared with the schematic at 459VDC as opposed to 427VDC probably within the tolerance. Also there is a 3.5 p-p ripple on the B+ which I think is normal.
With the amp on full volumen and if I watch the B+ on my scope I can see it drifting up and down by a few volts slowly and not in a regular manner. If I connect a guitar and watch the sag I can see that playing a low E causes a B+ sag of 25v until the note decays. Is that normal amount?
The Bias current on the power valves is: 20 and 22mA so that seems fairly well balanced.
