Hello everyone,
The parallel loop on all of these valvestates Iīs as far as I know(and I have an 8080 as well) shouldnīt let any preloop signal pass when the knob is set at full wet. My 8200 does so and itīs starting to be problem for certain setups. The dry signal strength seems to be as strong on dry as on wet.
Can anyone confirm that this is not normal and might know whatīs wrong? So far Iīve checked and replaced the following components:
- replaced the effects dry/wet pot (as well as most others)
- replaced the bigger elcoīs on pre-amp pcb (still waitng for the 4700uFīs for the power-pcb to show up)
- checked soldering on all boards
Amp works fine except for this problem and since I use some stereo effects the loop is essential. Iīm inclined to think the problem may be IC2B on the reverb/loop-pcb, but I donīt know enough about ICīs to see if itīs faulty. How do measure it with a multimeter and what should I expect?
Schematics are of the preamp and the reverb/effectloop pcbīs
Thanks!
Thanks!
