I am using a 6SL7 in a Tremolo Circuit. It ties the cats together and the grids together. Is there a problem with running those two jumper wires over the top of each other on the tube socket.? Or would it be better to run one of the jumper wires tight to the outside of the tube socket.?
What I am asking..... is it a problem if the leads for the cathodes and control grids cross over each other.?
Thank You
TDSL Tube data [6SL7-GT]
Thank You
