This is a continuation of the zombie thread I revived here: Ampeg B-100R Melting Bridge Recto
(apologies for the resurrection, if a moderator would like to move the more recent/relevant posts from that thread to this one, that might be helpful)
Quoting 52 Bill:
Yes, I pulled all 4 output transistors to check them out of circuit. Q5 is shorted from emitter to collector. I pulled Q5-8 and the amp powered up fully with no excess current draw. Q6 and Q7 seemed ok so I put them back in to see if the amp would stabilize, but something still draws too much current. I pulled Q8 because I am under the impression they more or less work in pairs - is that correct? (btw I am running this all on a light bulb limiter and variac, with no load on the output)
So either something is wrong with Q6/Q7, or there is another component that will only draw too much current with the output transistors in place.
I will double check Q3-Q9, and the 6 smaller 1n914 diodes in the power amp. I gave the smaller parts a cursory inspection but I need to take a closer look to see what else might be faulty. I should mention again that Q3 looked like it had a cold solder joint on the emitter.
Finding the short in Q5 kind of distracted me from the other stuff for a moment, and I didn't have time last night to investigate further.
Like I said, I ordered 2 whole new complements of semiconductors back through IC2, for about $20 shipped from mouser. I'll check the smaller SS parts I mentioned above for problems before installing the new stuff. Besides those and the bias and emitter resistors (already checked those Rs), are the any particular caps or resistors I should take a closer look at?
Quoting 52 Bill:
Did you actually remove all 4 outputs transistors? Did you test them all out of circuit before you put them back in? I can't say for sure, but as Enzo hinted, you may have caused some additional damage by running the amp that way. I try and remove as little as possible to test and repair anything that is in front of me.
It is very easy to test the outputs for shorts while in circuit, finding which one of two or more paralleled devices is bad takes a little more work, but in only pulling the bad devices, it allows you to test the rest of the circuitry before ordering parts. If you had just found the short and pulled Q5 you could then power up the amp through your limiter to see if the amp would have powered up normally. If it still drew too much current then you could look at the drivers, etc.
Check all of the transistors and diodes in the power amp in circuit. If anything doesn't check right, then pull something out to test it. If the power transistors have already been pulled then test them all out of circuit and then put them back in until you complete diagnosing the other problems. Try and limit the variables that you add to the mix until you know what is wrong with the amp.
