Hi all, I just finished rebuilding the output of a B2 and I have a couple of questions regarding the TP voltages. With a 1v signal in on pin 2, no load, TP7 and 8 measures 5.8 and 5.2vdc. And on TP9 and 10 there's 38vac on each and 2vdc apiece.
The 38vac and 2vdc are low compared to the schematic, is there a problem here?
Also, is it better not to bias until the mosfets are mounted to the heatsink? I'm find that the 27mvdc or so is going up as they get hot.
thanks!
thanks!
