I'm working on EBS TD650 bass amp. There is one ECC83 valve in the amp and it has very strange power supply. The heater is supplied from -62V through a 330 Ohms resistor. The voltage drop on the resistor is 51V so it means that the power dissipation of the resistor is 7.9W. Originally there was 7W resistor. I installed 10W resistor and measured its temperature after few minutes of work. And it's 140 degrees Celsius. According to the datasheet such resistor cannot handle 80% of load with this temperature. This is the worse design of the heater supply I have ever seen. What do you think? It's just asking for troubles .
Mark
Mark
