I get no term sound at all. I got this amp not too long ago as is with the term non working. The reverb works and I repaired/modded the footswitch by adding a 1/4" TRS plug and a TRS jack on the rear of the chassis so it can be disconnected. The switch activates the reverb but not the trem - I've unplugged the footswitch to make sure it just wasn't a wiring problem. The Reverb still works without the footswitch plugged in, the Trem does not.
How common is it for the TM-1 Optoisolator to go out? I know Fliptops carries a replacement but I'd like to make sure its not something else before I drop almost $40 for a replacement. I replaced the 3 25uf 25v Electrolytic caps - the Blue "Ducati." I was hoping the one near the trem was bad and that was causing the trem to fail but still no trem. What troubleshooting methods/tests should I conduct to either rule out other parts failure and or determine for sure its the TM-1? I don't have a scope so I can't test the Opto.
Thanks in advance.
Thanks in advance.
