i'm recapping a push pull MV twin and i noticed that many of the resistors are far from there spec values. for instance the power tube grid resistors are all at about 500K ohms when there supposed to be at 1500K ohm according to the schematics. the tube are more blues than i usually see. most of the other ones that i tested where all at about 1/2 of the schematic value.
are any of these resistors crucial to replace or just the electrolytic filter caps?
also the brown and blue coupling caps all look a bit rough, kind of lumpy. is this normal? they're not cracking, or leaking anything.
with all of this said the amps sounds really good, no hums or buzz, has plenty of clean head room, responsive eq. very clean signal just not as loud as im pretty sure it should be. i play it at about 5 or 6 on the master and about 4 on the channel volume to play with a fairly mild drummer. shouldn't i be reaching for the ear plugs about at that level....?
any advice or opinions would be greatly appreciated
