Good evening....(well it's 10:48 PM here), a quick question about an SVT...Had one come in for repair and had an output tube that was after turning white and blew.....also two other tubes in the other set of three were dead..they lit up but no emission at all...so I replaced all six with a matched set.....(supposedly) and noticed that I couldn't get the amp to bias evenly on both sides. I removed the 12AU7's and tested them in a tube tester.....tested ok for shorts and emissions..... put them back in and same thing....(grove tubes) and these were fairly new.......just for the hell of it, I replaced them with a set of JJ's and the biasing was good....it was very easy to set up. I checked both of the JJ's in the same tube tester and they tested exactly the same way....but the grove tubes 12AU7's affected the biasing drastically....any idea as to what would be causing this?? I realize that it is probably the tubes themselves...but what could be wrong with them??? I also heard that the JJ's are a better choice for tubes...is this true?? If it is then maybe I should be using these in all the amps...whenever I can.....any comments......quite welcome.....
Cheers,
Bernie
Cheers,
Bernie
