Amp on the bench doesn't have any volume or bass response unless you turn the treble up at least 1/2 way.
If treble is at 10 I get volume but volume drops around 7 and picks back up around 9, and volume never zeros out.
Bass response (with treble at 10) kicks in about half way with only minor effect.
Last time I ran into this was with a Prosonic that was wired incorrectly.
All the pots seem to be good, and are clean. All voltages are good, no buzz. Connections appear to be tight, grounds look good.
When you find a working mix of equalizer settings the amp actually sounds pretty good.
Below is a link for the schematic. Any thoughts?
http://www.musicandelectronics.com/m...s-Model-50.pdf
