I'm trying to fix an AXL Akita AT-40 amp that's got me scratching my head. The unit originally powered up, but hummed badly and was passing tone poorly. I replaced the main filter caps, C70,71 with same brand and capacitance but higher voltage - 220uF 450v.
When I brought the unit back up with the variac, I got a light snap sound like a fuse blowing, but all fuses are fine. I had forgot to secure the output xfmr taps to their respective lugs on the PCB. Once that was resolved, I'm not getting any B+ voltage at all, but instead I have -250vdc at D12,13 thru the STBY switch. All other PT taps are yielding correct Vdc's in thier circuits. Checked all resistors & rectifiers-OK. Replaced D14,15. Even pulled a leg on R82. 100% positive I installed the filters correctly(double checked).
Geez, I know it must be something I'm overlooking, but my feeble brain is in no comprende over this one. Can anyone shed some light for me?
