Originally posted by soundguruman
View Post
Fender Hot Rod Deville "more drive" issue
Okay, let's make this really interesting.... I pretty much agree with or at least concede to the logic and experience of Enzo, whereas the advice Guru gives...meh...
Anybody want to start a poll on whose advice they trust/prefer? And, yes, even though I realize JFETs are very easily damaged and opamps almost as bad, I agree that the extra soldering to put in sockets is a lousy idea. Sockets can cause more problems than they cure. Use your soldering iron properly and be prepared to repair lifted pads/damaged traces. I can't believe I'm the only person here that has seen chips "walk" out of the socket from temperature cycling, or get corroded contacts, etc. If you really want to save damage to the PCB, clip the wires below the body of the FET and tag-solder the new FETs to the legs for testing - "a little dab will do ya" and it's easy to swap FETs before commiting to the full desolder/re-solder.
Okay, I'm finished derailing this conversation - now back to helping solve the problem of the original poster....
