Hey guys!
So I have an SWR Bass 750 amp on the bench that seems to have a strange issue in the power amp circuit. It originally came in for repair because the owner had decided it was a good idea to run it on a 1/2 ohm load for God knows how long until it finally gave up the ghost. As usual I replaced the outputs Q9 thru Q14, the drivers Q7 and Q8, as well as a few other components - Q3, R13, R14, R15, R18, and C7. Q3 had gotten so hot that the heatsink changed color, and R14 and R18 had unsoldered themselves from the board. So after all that I biased it using the crossover notch method, got a good waveform, and everything seemed OK until I realized that Q3 was burning up again, while everything else is running cool. I've been over this a hundred times already and I know that there were some design issues with this circuit, but this is killing me. Any ideas? Btw, this is the Revision 'E' power amp board but I did find one discrepancy - R15 is a 470R instead of 27R. Thanks guys!
