I am working on a Gibson GA6 amplifier. Very simple circuit... one 5Y3; two 6V6; two 12AX7. I have replaced the DC filter caps as they were original and leaking. The ripple voltage after the cap replacement is around 2.5vp-p... I'm cool with this. I can trace my test input signal all the way up to the 6V6's and it looks good. Problem is... no output. When I scope the output of the tubes going to the output transformer I get nothing that looks like the amplified input signal. I have measured the output transformer end to end and I measure ~ 450 ohms. I swapped the output tubes with known good 6V6's and I still get the same thing. The B1 voltage measures 430vdc.
Some observations:
1. I removed the wires going to the OT from the 6V6's and scratched them on the chassis... I can here static coming from the speaker. (weird??)
2. The OT is mounted on the Jensen speaker and the primary wires have tape on them and there appears to be burn marks on the transformer where the wires enter the primary side. It looks like something shorted and the repair was to wrap black electrical tape around the wires. Basically, a bubble gum repair and McGubber's finest work!
3. As mentioned above, I have signal all the way down to the 6V6's and the output of the 6V6' looks wierd. Is there a way I can put a resistor or something similar across the output of the 6V6 pair and simulate the OT?
Thanks,
CJ
Some observations:
Thanks,
CJ
