a guy brought me his ibanez 4x12, switchable between 8-ohm stereo and 4-or-16ohm mono, similar to the modern Marshall 4x12 arrangement. one of the plastic threaded bushings broke off one of the jacks. No problem....zip zip...desoldered and installed a new jack. I went to meter the outputs to verify the combinations of impedences....i got some wacky readings. I took the back panel off and metered each speaker...all normal around 15-16 ohms.
i had a closer look at the jacks....they are wired backwards from a typical cliff-style jack. on the ibanez jacks, the switch is on the other side of the jack compared to the cliff-style. i tried pulling the contact elements off of a cliff jack to see if i could swap them around, but i can't get them off without destroying them. i guess i am calling ibanez in the morning....
