I have a PT that I accidentally shorted-to-ground a while back (bad circuit wiring on my part - the Mains fuse blew instantaneously at the time IIRC) and today I thought I'd test it properly, just for a what-the-heck? moment. It used to work fine for years.
So I have wired up the PT into a chassis and have all the secondaries wired to unconnected terminal strips. If I disconnect the CTs for the HT and heater windings from the chassis, there is no DC resistance between any of the secondary windings, or between any of the secondaries and the chassis. There is no DC resistance between the primary and any of the secondaries. When I connect the CTs for the HT winding and the 6.3V winding, they are bolted securely to the chassis and I get DC resistance/continuity accordingly.
The 3-chord main is grounded with a dedicated chassis ground. I have a 1R 5W power resistor in series with the active/phase mains wire, and without any meter across any of the secondaries, there is virtually no VAC voltage drop across this resistor (0.11VAC/1R = 0.11A, i.e. 0.0121W), and the fuse is fine. I have the active/phase wire fused with 250mA Slo Blo.
What's more, I can meter across either the HT winding or the rectifier winding okay (and get good VAC readings - 695VAC and 5.3VAc respectively).
But when I try to VACmeter across either the 50V winding or the 6.3V winding, the mains fuse blows (instantaneously in either case). How come this happens, even though there is no current to speak of across the primary (as measured through the 1R power resistor?) and otherwise no load on the PT secondaries? Go figure (please?).
Schematic of wiring diagram FWIW
