I've got Peavey 5150, which I was told makes some strange noises. I couldn't reproduce the noises but I found this:
![Click image for larger version
This is the connector between the power valves board and the main board of the amp. It was already fixed (with two additional wires) but the board may be conducting. I think that I have to remove carbonized board and see what else is wrong with the amp. I also need to replace 100R grid resistor. It was already replaced by some lazy guy with a huge resistor taken out of probably a russian TV. I need to fit a proper one. How do you remove the power valves board?
Mark
Mark
