Peavey valveking 212 repair
I need help
what is correct voltage MM readings for Valveking 212 for all preamp/ power tubes pins to ground? (with no tubes installed) I have 470V on V1 pin 1 preamp tube, Is it any stress/ excessive voltage exposure for other components with no tubes installed? Are the valveking filter caps are properly rated for the margin, (550V?)
I need help
