I posted a thread long ago about a hum problem, and never got it resolved, thought I'd give it another shot here.
The .50 Cal+ seems to generate way too much 60hz hum (or it could be 120, not sure) under normal operating conditions. I've replaced all the power supply filter caps, and checked the power supply under full power, and there's very little ripple, so power supply seems very good. I've replaced all the preamp tubes with new ones. Using a scope and a "noise grounding" test probe with a large audio coupling cap with one end grounded, I've isolated the source of the hum, it seems, to V2B or V3B (V2B is right after the tone stack, and V3B is the stage right after that... the reverb "driver"). I checked carefully under bright light for any possible black burnt streaks or areas in and around these tubes on the pcb, and see nothing bad there (thinking perhaps conductive pcb). None of the R's or caps seems to be burned or otherwise conducting to a trace underneath them.
Can this be a heater hum problem? There is no way on earth I would've designed this board the way the heater paths are... it seems the design/layout just begs for problems with electromagnetic noise. Two questions:
1) Has anyone perhaps tried to raise the DC potential of the 6.3V heater supply on one of these amps? If yes, what values of parts did you use, and how high would you raise the DC potential? (it would be a positive voltage, right?)
2) The 6L6's also run off the same heater supply; applying the new DC potential to the center of the two 100R reference resistors would raise the heater supply on the 6L6's as well... is there a problem with this?
Thanks kindly for any experience / advice on this!
Best,
Chevy
Best,
Chevy
