Bogner Uberschall - Impedance Selector
  • Bogner Uberschall - Impedance Selector
    Anyone know where I can get a speaker impedance selector switch for a Bogner Uberschall? Mine fell apart I've checked every switch manufacturer I can think of from A-Z , about thirty of them and come up blank.
    Thanks,
    Nic
    Just in case anyone ever needs the info, I found it, eventually. It a Schurter 0033.4032. Tucked away under 'voltage selectors'.
    Nick
      Nice! That's a good part to know about. Not rated a whole lot better than the cheap CK rotary switches but it's an easy to use form factor for homebuilt stuff and already labeled for guitar impedances.
      Found it on a google search in stock at onlinecomponents.com. I wonder what it would take to get Mouser or Digikey to stock it?
      jamie
        Very handy thread, looking for one of these right now...Did you managed to find an correct (impedance) labelled one ?
        thanks !
          The one I found (Schurter 0033.4032) is correctly labelled with impedance.
            It is a fairly fragile selector model. The only advantage it has is that when it breaks, it is seen that it is broken :-)
