Hi there,
I have a Peavey Windsor Head that had minimal output & a lot of hum in it's place. First thing I did was plug an effects processor in the effects loop & played through that, sounded great. That eliminated the power amp as a problem. Next I found the schematic online, checked the voltages a preamp tubes V1 and V2. The voltages seemed reasonable. Then I guess by a stroke of luck I happened to have the guitar cable halfway in the low gain input and, walla, it's working. If I plugged all the way in then it no longer worked. I tried the same thing with the high gain input, but it didn't work whether halfway in or all the way in.
Wondered if anyone out there has an idea of what is going on? R1 seems a little bit wobbly in it's space on the PC board, but I have not taken the board out yet. Thanks, Jon.
