I'm a bit stumped - can anyone work this one out? I'm getting circuit blindness and I must be missing something obvious (or not...)
This amp blows fuses and shows a short - the light bulb tester lights up brightly.
I traced it down to the HT and bias supply areas at the bottom of the diagram, around the bridge rectifiers DB201 and DB202. Lifting the black wire from the mains txr puts the light out.
With R213, C210 and the + connection from DB202 to the CT and the HT supply lifted, the light bulb still is bright showing a short.
With C212 lifted the light bulb indicator shows no short
With everything reconnected but with EITHER DB201 OR DB202 removed, the light bulb shows no short.
Both DB201 and DB202 test good on all four diodes.
Any ideas?
6100___6101_Power_amp.pdf
Any ideas?
