Does anyone here have a schematic for a Crate DX 212? This came to me a couple of days ago and the ribbon cable that connects the input jack board to the pre amp board was broken off at the jack board. I carefully marked everything and hardwired the jacks to the pre amp board. I fear that i've damaged a tracing somewhere or it was already damaged. I removed all the wire i used to re wire the jacks and i don't even get a hum from the pre amp.The initial problem was a crackle that was cause by cracked solder joints on the filter caps. That's fixed. I guess i could put a signal into the line in jack and see what happens. Well, i just ran a signal into the line in jack and nothing. I'll pull the output board back out tomorrow and have another look. I still need a schematic though. Thanks.
Crate dx 212 preamp schematic
