Hey all! So I'm currently redecorating the interior of a 1961 Gibson GA-6 Lancer, giving it new caps (new board for the filters too), and a less "rats nesty" wiring job. Since I first got the amp, it's had odd problems with a high pitch squelch on vol. 2 around 8ish, slight oscillation at high volume and hum throughout. I decided to take the almost 5D3 style circuit even more towards the Fender 5E3 schematic with .1uf coupling caps and 16uf filter caps, 1500k grid stoppers and added the V2 and V3/4 cathode bypass capacitors. The re-wiring was completely needed. I can't believe how bad Gibson's 50's and 60's amps were made! Half the parts not on the board are obviously picked up off the shop floor and reused. Anyhow...
So I just finished the rewiring and was sooooo stoked to find my voltage just about the exact same as after the cap change and before I started the rewire. On turning up the volume pots (nothing plugged in) I noticed a lot more hum and thumping oscillation that would come in at 9 or so on each channel. Channel 2 still has the squelch only it now starts EARLIER at about 6 on the pot!
Any ideas on where the hell I went wrong???
