Stereo outputs on Orange Tiny Terror
  • Stereo outputs on Orange Tiny Terror
    Hello, I have an Orange Tiny Terror Head which has two 8 ohm outputs and one 16 ohm output. I have that running to a Marshall 1936 Lead cabinet which runs 8 ohms mono and 16 ohms per side stereo (there are two inputs). Right now I have one of the 8 ohm outputs going into the mono setting and it works fine, but i was wondering if I could run the amp stereo and plug each of the 8 ohm outputs into the 16 ohm inputs, or would that be bad? Thanks for the help.
    They are not stereo outputs. They are just different ways of using the OT taps. Your description of how your connected is unclear. What you propose, plugging a 16 ohm cab into each of the 8 ohm outputs, is fine. But it's not stereo. Here's the owners manual:
    http://www.orangeamps.com/wp-content...al_01.CV01.pdf
      Agree and add: plugging both speaker jacks into both amp 8 ohm jacks is electrically the same as connecting the 8 ohm cabinet jack to one 8 ohm head output jack.
      Since the latter option is simpler, continue using it.
      casinolevant levant casino
