Hi all,
I’m having a problem in my 5E3. Here is the description:
As turned on, the amp makes several scratches sounds and static, with some pops. After a while, it normalizes operations.
While, the operation is not normal, the sound is distorted, very overdriven and low.
I’m made the following debug operations so far:
- Changed the 5Y3
- New set of JJ 6v6
- Unplugged preamp tubes to check if the problem was on the preamp stage (the sound remains)
- I’ve checked PT voltages and they are ok. A little bit higher due to European power grid, but ok.
When the problem is active, I have strange readings in the plate (pin 3):
Tube 1: 379v
Tube 2: 354v
In the screen (pin 4) both voltages are equal in abnormal operation: 286v
In normal operation both plates have same voltages.
I was considering some sources of the problem:
- Plate resistor. This would not explain the difference in voltages
- Grid resistor. This would make sense since it would induce distinct voltages.
- Caps. The popping sound and resuming of normal operation could indicate a cap problem?
- Coupling cap. This would not explain the different voltage.
Any suggestions or directions that you would like to point me out are most welcome.
Thank you in advance.
- Changed the 5Y3
- New set of JJ 6v6
Tube 1: 379v
Tube 2: 354v
