Hi there
Yes I'm stumped at the moment with this Marshall Valvestate 2000 AVT 150.
Came in with stories of someone attempting to plug the output into a mixer -
speaker out instead of emulated out so basically a short on the output.
I ordered in two new TDA 7293v and set about removing the old chips and cleaning
the little pcb's ready for the new chips.
While I was waiting checked the power supply via a light bulb limiter - was approx
plus and minus 43volts and inspected the board with a jewellers eyeglass for any damage.
Having already repaired one of those mode 4 Marshalls with a similar fault (all 4 o/p chips replaced)
and observing that the power supply has to be discharged before connecting them up I thought
it would be a straight foward repair but no the light bulb limiter started glowing a bit more and
I hit the off button pronto.
Post mortum revealed major internal shorts on both chips (eg positive supply pin and negative supply pin
shorted) no signs of smoke or any signs of damage anywhere !
So ordered 2 more chips and same again !
I have been very careful to make sure there are no signs of solder splashes on the board.
Cleaned it with isopropyl alcohol and a small tooth brush then checked it with a jewellers
eyeglass again for shorts ... both times.
Checked for DC on input at the connector the little output boards plug into and using a sig gen and scope
saw that there was signal at the emulated output and at pin 2.
Read somewhere another tech had a problem with the bootstrap loader pin not connected so checked
the two caps with a meter C216 & C191 22uF 50v that connect between the master and slave.
They both are not shorted and charged/discharged in a similar fashion with my meter.
I did notice a tiny bit of ripple on one of the supply rails and at the moment am stumped !
Reading stories on line about replacing that setup with a more traditional bipolar o/p stage almost make sense !!!
Any help greatly appreciated.
Attaching a butchered um altered schematic with the parts for the AVT275 in a light blue (not fitted) showing the
complete output stage but only showing one module of the identical pair.
