Hello everyone,
Possibly silly question...
I'm trying to turn a (free) Stromberg PA into a guitar amp. It wasn't intact, some power supply components missing - power cord, caps, etc. Basically trying to use trannies & chassis. Wanted to check the PT out. It looks okay
I went through RG's tests, ohming out windings (all okay) & checking voltages totally unloaded (all okay). Don't have the neon short tester, though I did do the "leave it on and powered" test for 12 minutes. It never got above the outside air temp.
Here's my question: for fun & experimentation, I checked voltages between 2ndary windings, as in, one leg of HV to one leg of 6V heater. Got about 170 volts. Also, got about 5V between the two heater windings - 5V/6V (has tube recto). So, would this be a short, or just inductance that happens naturally? AC in a coil in close proximity to another coil, etc... since windings aren't connected together in the amp either? As I said, never got even warm. Just wondering if this is normal? I could take the PT out of another functioning amp, I guess...
Thanks to everyone with their patience!
Justin Thomas
![Stick Out Tongue](https://music-electronics-forum.com/core/images/smilies/tongue.png)
Justin Thomas
