Hello all,
Thanks for having a great forum. I recently purchased a 70's 100wt MV twin Reverb chassis (actually a Super Six, but same thing). It appeared to be mostly stock. It hummed a bit when I got it, but had original caps so I wasn't surprised. I have since replaced the filter caps in the doghouse as well as the 25uf caps on the board. I have done a lot of testing and have the following symptoms:
-Pretty loud 120hz buzz, and slightly lower 60hz hum.
-Pulling tubes has only stopped the hum when V4 or V6 is pulled, leading me to believe the problem is in the preamp section.
-The 120hz buzzs "nulls" (greatly reduces) when I put either channels volume around 4, leaving mostly 60hz hum. 120 buzz is loudest when both channels are at 0. When both channels are at 4, the hum does not reduce - only reduces when 1 channels is at 4ish. I think I head that the channels on a twin are out of phase with each other?
-Master volume turns down the both hums. The pull boost greatly increases 120 hz.
-I have swapped out every tube with no reduction. Hum balance also set to lowest hum, even with only 1 pair of output tubes.
Other notes:
-I have done reverb/trem to both channels mod, but disconnecting has no effect on hum.
-I currently have the NFB wire disconnected as I like the clean sound better. Reconnecting has no effect on hum.
-B+ on power tubes is 465v on all.
-Rectifier puts out 467v and -66v. Bias at power tubes is -53.
As you can probably tell, I know just enough to be dangerous (tho I do drain my caps, etc), but I dont really understand all that's going on in tube amps. I usually try troubleshooting by swapping things out, looking for obvious problems, etc. When that fails, I used to bring it to a tech. I would like to get better at this, so any help would be much appreciated.
Pictures posted soon.
Thanks!
Robert
Other notes:
Thanks!
Robert
