I have a problem with a Mesa Stiletto amp that I want to try to diagnose myself as I have been trying to educate myself on tube amp repairs. I know the safety issues involved and necessary precautions. I have a mechanical engineering background so limited electronics experience beyond a few fx pedal builds and amp mods but building up an understanding as I go.
Problem: Low rumble that can be heard and felt (speaker cab vibrates, things placed on the amp rattle. Its audible too but not very loud. The amp all works, although holding a note I can hear the 50Hz, like a fast tremolo. The amp seems to run very hot and the sound is rather compressed, also seems low on power for 100W. Checked with my simple hand held scope and saw 7.5Vac on the speaker output (speaker plugged in, no input signal) and a very clean sinusoidal output!! Used scope to check frequency and got 43.1Hz, did same on the mains power switch and also 43.1Hz, so its mains frequency hum. Changing modes eg bold/spongy, tube/Si rectifier. 50/100W changes amplitude but doesn’t eliminate it. Worst is Si, 100W, bold - as probably expected as that’s max. power setting. Its worse in 4ohm socket. Did the same check on my other tube amp and got a few mV noise - a factor of several hundred less. I guess all this lost power wound explain the hot running.
Checks so far:- Rumble is loudest with master vol at 0 and reduces as master is > ½ way. Connected from fx send to another amp – noise doesn’t transfer and preamp sounds good. Plugged cable into fx retn to disconnect preamp from power section - no change in noise. Guess that all means the problem is in the power amp? Checked ripple at the standby switch, after main filter caps - trace looks normal and 1.15Vac, didn't seem bad on 470V dc. Anyway I think noise would be 100Hz if it was power supply. Pulling phase inverter tube stops the noise dead. PI tube is new and trying another has no effect. If it’s all quiet with no PI, my interpretation is that power supply/EL34s (not replaced)/bias supply/tube sockets are not the cause as noise caused there would still appear at output transformer. So I think maybe I have narrowed the problem to somewhere around the effects return ½ tube, PI or negative feedback circuit. I wondered whether there could be some positive feedback going on? As I bought the amp used (I don’t think its ever been right) I can’t be certain that it’s never been modified or messed about with but all seems straight inside. All earths from board to chassis seem secure. Using stick to shift wires etc had no effect.
Next job to try to identify the components/signal path for this part of the circuit on the board (I have a schematic) but it will be tricky as the traces are small and disappear under components. If I need to I will take it to a tech but I would really like to figure this out myself and learn in the process so any ideas would be appreciated. Thank you.
