Amp will play from 10 to 20 minutes then its as if something shorts out (like if you grounded out your guitar cable). The loud sound continues until the amp is turned off and is not affected by any of the volume/tone controls or switches. Shutting off the amp and back on, you then can only play about 30 seconds before it repeats. The effects out jack does not pass this sound, but the amp simulator does, so its happening in the power section. Tubes have been replaced. The amp can be on for hours without passing any sound (not playing guitar). But as soon as I pick up the guitar and play a few notes - there it goes again. So what would be suspect first?
BTW: Marshall manual sez that when the effects are turned off, and the effects loop switch is off - it does bypass the digital circuitry. So I don't suspect anything happening there.
