Hello!
I've been working through a Peavey Bass 400 Series A that came to me from a friend with a few issues. The original owner had attempted to repair the amp and did so pretty shoddily. A friend of mine picked it up and replaced the power cord and filter caps. However, one filter cap - that on the -40V line - was replaced backwards and exploded. Prior to the cap replacement the amplifier worked.
I replaced the blown filter cap with a properly oriented one and replaced the rectifier diodes as one tested bad in-circuit and I wasn't receiving -40V. The output transistors were also replaced as one was shorted (though that transistor may be unrelated and my fault during the testing process). Currently when running the amplifier through a light bulb limiter it registers as fine without a load attached, but once a load is attached it registers as a short. Currently I read roughly +40V, -40V, and +24V where expected; I say roughly as I have done the readings with the limiter in place.
Any ideas on what might be the culprit? Thanks in advance for any help!
Chris
Chris
