Hi, folks
Anybody have access to early Eden amp schematics or BOMs? Pre-2000. Current US distributor (US Music) where I have a field service contract only has schematics for post-2003. This one's very different. Normal web search came up empty. I need to identify an LED on the power supply board.
Background:
An Eden Metro came into the shop with a problem with no output even though line current draw was normal. Turns out there's a control voltage which mutes the power amp until it's up and stable. Something like -12VDC needs to be on pin 5 of the header of the power amp board. As received, there was nada, zip on that pin. No negative voltage, no sound. Simple as that.
Cause:
An LED in series with the mute voltage circuit, located next to the bank of filter caps on the power supply board was open. Without a good LED, there was no de-mute voltage on Power Amp pin 5. It was a very small LED with a slightly pink lens. Since it was open, there's no way to determine the proper forward voltage. And, of course, LEDs don't sport part numbers.
Temporary fix:
I assumed the function of the LED was to drop the control voltage to a safer value and to act somewhat as an onrush current limiter during charging of the muting circuit. . (the de-mute voltage appears on the gate of a J112 N-ch FET on the power amp which, in the absence of a gate voltage, would shunt all input signal to ground. I wasn't sure of the correct forward voltage of the LED so I chose one with a pretty high FV: A big-ass blue one. Amp works now.
Nagging problem:
I'm just not sure if I used the correct LED. It glows really bright blue. Could the original have been an IR unit, which can withstand higher currents, but having a lower FV? I'm just not sure and the 2003 power supply board (for which I have schematics) doesn't have an LED in the mute circuit.
Humerous aside:
This is sort of funny. The location on the circuit board shows a standard LED symbol...cathode, anode and zig zag arrow coming out. There's also a "+" symbol on one of the terminals. The "+" symbol on an LED usually denotes the anode, but it was on the terminal which was shown to be the CATHODE according to the silkscreened LED symbol. HAH! Which one was right? I went with my gut and followed the "+" indication and not the LED symbol. Voila, the amp works, but I'm STILL not convinced I used the right LED.
Why did the LED fail?
I'm not sure. The amp seems to be fine, but the LED is on the opposite side of the PCB from a pair of big 10W resistors serving the fan & protection circuit. The resistor is flown RIGHT over the solder side of the LED (cushioned by a little glob of RTV. I'm guessing repeated heating of the resistor baked the LED. No wonder they discontinued this power supply board!
Bragging rights goes to anybody who knows what kind of LED this should be! It's small with a slightly pink lens.
Thanks!!!
Background:
Cause:
Temporary fix:
Nagging problem:
Humerous aside:
Thanks!!!
