I'm working on a Sho-Bud; date codes on caps appear to be from 1972. Single channel w/Reverb. It came from Europe back the US - had a step-down transformer mounted in the cabinet. Anyway, it had been in storage for 20 or so years and was brought to me to check over and make it work on 120vAC. I brought it up slowly with a variac and all was well 'til I hit 115v or so: one of the 100Ω resistors burned, a .33Ω resistor opened and the outputs shorted.
The amp uses two 2N3773 outputs, which I was able to find at Mouser. I replaced the resistors and outputs and tried the amp: No output. I suspected the drivers and removed them from the board and tested them. The 40407 tested OK, the other side had a 2N4314 which tested bad. I replaced the 2N4314 with an NTE129 and tried again. The amp passes signal but it is weak and distorted. I adjusted the bias, but that doesn't clean it up and the output transistor on the side that now has the NTE129 driver (positive side?) becomes hot while the other side remains cool at idle.
I have no schematic for this amp, but have been using the schematic for the amp that uses 40636 outputs just to get some idea of a Sho-Bud circuit.
My Questions:
1. Is the 2N4314 what Sho-Bud originally used? I would have thought it would had been a 404xx.
2. What can I use to replace both drivers? NTE128 & NTE129, or are there better alternatives?
3. If the NTE129 I used is weak or "going bad", would that cause the issues (weak output, distorted, 2N3773 on that side heating up)?
4. Any idea what the correct bias current would be?
Thanks for any help offered.
My Questions:
