Is a 6AQ8 almost equivalent to a 12AX7? Are they interchangeable?
  • Is a 6AQ8 almost equivalent to a 12AX7? Are they interchangeable?
    Just like the subject line says...
    I think I see that that pin-outs of a 12AX7 is the same as a 6AQ8. Can one swap for the other (even sort of)?
    Thanks!
    -=- Boris
    Well, I'd say electrically it is a lot more like a 12AT7 than a 12AX7.
    The pinouts are not the same. Look at the heaters.
    If you wired up a socket with 6v across pins 4 and 5 it would light up and probably work. The typical wiring for 12AX7s on 6v is 4 and 5 wired together with the 6v across them and pin 9.
      Thanks!
      -=- Boris
