I just had a first. I was finishing a SS amp repair and it worked, but just looked a little odd on the scope. The positive-going output seemed a little compressed compared to the other polarity. The output had paralleled bipolars, and one of the top-side pair was hotter than the other. In fact, it got distinctly HOT. But nothing was really burning up, and the signal was coming out, even at 100W into 2 ohms.
Pulled the hot one out. It was fine.
Tested wiring to it. OK.
Tested base drive - just fine.
I cleaned up the socket contacts, and spend a half-hour searching for my heat sink goo, then put it back in. Still fine.
It finally got through to me to wonder not why this one was hot, but why the other parallel device was cold. I probed the cold one and found that its emitter was always about half a volt below the collector, up at about 40Vdc. Shorted?
Nope, can't be. The output is rising just fine, and the fuses are not exploded.
Hah! Busted emitter wire.
No, the wires are just fine.
I finally tried the meter on the 0.33 ohm emitter resistor. It read open on the 20M scale. This was a 5W wirewound resistor with no visible heat damage at all. It looked like it had never overheated. Apparently it just opened.
Never saw that one before. I've seen overheated - nay, nearly exploded! - emitter resistors and other cement wirewounds, but never just quietly open.
The lesson? Trust nothing to be OK until you personally meter it.
