Glad to hear that it's working. Whenever I mount a power transistor, as soon as it is tightened down, I test for continuity from chassis to case. Because the collector is wired to the power supply there will often be some sort of reading, but except for a few rare amps, there will never be a constant low reading.
On Kustom amps the collector wire is separate from the mounting screws, so as soon as the transistor is mounted, you can test for continuity between the case and the chassis before connecting it to the circuit.
Now get to work on the preamp problem!
