Totally reworked a Silvertone 1474 and rebuilt the reverb circuit to use a standard tank with a transformer driving it.
I rewired the first stage to a standard heater configuration, and used a 6CG7 as the reverb driver and return stage.
Now, stock that stage was a 12AX7 for send and return of the crystal reverb "tube"
Any idea why they wired that stage to run a 12AX7 with just 6v to pins 4 & 5?
I like the way the amp/reverb turned out, but I was experimenting with some other tubes like a 6AQ8 and 6Bq7 and think that stage might have sounded better if I had kept a 12AX7 there and rewired it for a standard heater layout.
It doesn't want to conduct properly with 6v between 4 & 5.
