Hey all. Relative had a YBA-1 sitting around and gave it to me. Man oh man. I have wanted one of these for a long time. It needs work but sounds plain amazing.
Someone had incorrectly installed a 3 prong cord so I redid that the same way I've done it dozens of times. It kept tripping the breaker. I swapped the wires around several different ways until it stopped tripping the breaker.
I installed a larmar same way as I have a dozen times on several amps - keeps tripping the breaker. Here's a pic of where I was at before I gave up for the night in frustration.
![Click image for larger version
The red and white wires are going to a dual 100k pot with 220k resistors (100k pot and 220k in par. - 68k). The black lead between them is the pot ground connected to where the 68k resistors met (in a Marshall circuit these would be 220k - lower here per original schematic likely because of the higher voltages) and grounded through the bias ground.
I also removed the 1k5 resistors that joined the negative side of the .1 Caps and went to pin 5 of the output tubes. I tied these resistors to pin 6 and connected leads from here (the yellow wires) to the other set of wipers on the mv pot.
Everything is as it should be but I keep tripping the blankety blank blank circuit breaker. Any ideas?
A tech friend of mine said to try a straight Fisher MV using a 250k dual pot with no safety resistors. I did so but could immediately tell something was wrong.
