I am a hobby amp builder, but not an amp tech. I have a friend with an old Fender DR AB163 circuit with an intermitant problem that I have never run into in my limited experience. The problem is intermitant noise or static (almost sounds like a bad shorting jack but it makes the sound regardless of whether a guitar is plugged in or not) and sometimes sounds like static on an AM radio. The sound varies in intensity rushing louder and then stops. Later to return. I found it will occur more often when switching on standby after the preamp filters are fully drained of voltage.
Here is what I have done and some observations:
1. Checked all B+ voltages (pin 1 & 6 of preamp section, pins 1 & 6 of PI and pins 3 & 6 of the PT) and the bias voltage. B+1 was 415 vdc and the rest were all relatively in line with schematic. Bias voltage checked out too.
2. After replicating the problem; I pulled all the preamp tubes one at a time; but the noise continued
3. However it stopped when I pulled the PI tube.
4. Replaced PI tube; but the noise continued.
5. Inspected electrolytics. They had all been recapped before my friend purchased the amp; they appear to be in good shape.
6. Checked the amp's circuit board and other grounds, they appear to be solid, but I have not pulled the board to inspect the underside and someone in the past has replaced some resisters.
7. The non-electrolytic caps in the amp are all original.
8. I can make the problem worse by flipping the standby swtich off and back on. Also, when turning off standby the amp sometimes will make a "pop" sound & when it does, I usually can get the problem to re-occur, even when the preamp electrolytics are charged, by flipping the switch back on.
When the problem is not present, the amp plays like it should and frankly sounds awesome.
On my list to check are:
1. Heater solder joints
2. Change out power & rectifier tubes (I have a test pair of 6v6's and a test rectifier)
After that I have exhausted my ability to find the problem. Before I have my friend take the amp to one of you, I wanted to ask for insight and suggestion. Thanks, I haven't posted for a while because I have been learning about and building D-clone amps with the help of folks at TAG.
