New Month We are at $45 this month in Donations.Please consider making a donation. :)
Happy NEW YEARS!!!!!!
Replacing 6L6s with 5881s - JMF Spectra 60t - No Bias Adj - Mod Suggestions?
And don't try to replace 6L6GCs with "re issue" 5881s. I'm not talking about the Sovwreck 6L work alikes that have 6L6WGC/5881 printed on them. Those are 6L6 replacements.
Thanks for the heads-up, I'm surprised to see the tubedepot suggest they can be used in "any 6L6 tube amp", and comparing them to JAN6L6WGB, which can take high plate voltages.
This is more like it: Tung-Sol 5881
("There are some important things to know about the reissue Tungsol 5881 tube before you decide to use it. The Tungsol 5881 is a 23 watt tube and is rated for a maximum plate voltage of 400Vdc.)
That '-44Vdc' bias voltage sounds more like a EL34 voltage range.
You could try lowering the 15K resistor on the bias supply.
I get the feeling that you do not have enough B- to start with.
-50Vdc to -55Vdc would be more like it.
You could try measuring the voltage right at the diodes for the 18 volt supply to see what is 'available'.
Good point Jazz. will check the the 18v supply rec diodes tonight. I believe the 60-T is originally a 2x6L6 amp, but haven't been able to confirm. There are reviews that suggest the 120-T uses 4x6L6.
If normal troubleshooting does not get the bias voltage high enough, you could either use a doubler circuit to get more voltage or tap off the high tension winding to get there.
And just for history, the A supply fed the heaters. In the old days, portable tube radios had "ABC batteries" in them, that provided all three supplies.
Agreed.
The correct name is C for the bias supply.
As I really hate typing, I mearly indicated the letter on the schematic.
B.
Then I gave it the minus sign to designate the negative supply.
