Hi all,
New guy here.
Firstly,I have no training in electronics,but I like to have a go and have managed to fix more than 20 dead amps in the past few years.However,this Selmer has got me stumped.
I bought it on Ebay as a working amp,but when I plugged it in,there was a lot of popping and only a barely audible signal from one channel.Then a huge humming noise with one EL34 looking as if it would burst into flames.The seller assured me it was working and claimed it must have been damaged in transit.I'm dubious.
I replaced the EL34 bases and and the 10 watt resistor,,,,,,it sounded great for 30 mins and then I switched it off.I put it back in the cab and then it wouldn't work.Now a very low volume from all 4 channels,but louder when plugged into the echo return channel.
I found wrong value resistors and replaced them (the bias resistor was 3 point 9 K).The voltages seem to be higher than the drawing and I can't get a voltage drop on 2 resistors.The big caps look all original but as I had the thing working for a while I didn't suspect them.Changed all the valves for known working ones and then smoke from a EL34 base.
Any thoughts would be well appreciated or anyone in the Glasgow area who would be willing to have a look,even better.
Thanks a lot,,,,,,,John.
New guy here.
